True, but lets clarify that OP mentioned 210.52 which is only for dwellings other than when referenced by another section.The 2020 NEC has come up with expanded requirements for required receptacles in things like conference rooms. You first calculate the number of receptacles required and then you have to install that many receptacles. The locations however are up to the designer.
Yes, the title of the thread is Non Dwelling Occupancies, that and Don's post are what I was responding to. But you're correct the cited article is not for non-dwellings.True, but lets clarify that OP mentioned 210.52 which is only for dwellings other than when referenced by another section.
That requirement is in 210.65.
