tonyou812 said:
I'm not really much of a "motor" head but can anyone tell me what is the difference between diesel fuel and kerosene? Years ago when i worked for another EC he had all box trucks that were diesel, and sometimes when it was really cold out the fuel would gell up a little and the engine would really struggle to stay on. So the boss told us to put in little kerosene to thin out the diesel fuel, and it worked. well the other day I noticed that kerosene is alot cheaper than diesel, which made me wonder would it be bad to mix the two. Not that I am going to do it but just curious.
it's about the viscosity of #1 diesel, so if you are in alaska or something,
you probably could run it during the winter..... but the cost differential
isn't worth killing your injector pump. it doesn't have the lubrication ability
of #2 diesel.
even further off topic is the subject of running your diesel rig on
CNG. there's a guy in ohio who makes hybrid kits to run off CNG
and diesel at the same time. i'm running an E-350 with a diesel,
and it would drop my fuel costs about 70% in calif. the only reason
i am not running it is that tanks are unavailable since Utah locked
their CNG price at 65 cents a gallon, and everyone is converting,
and creating a shortage of tanks. you are using two fuels at the
same time, you are getting about 25 MPG on the CNG, and 60 MPG
on the diesel. and about 100 extra horsepower at the rear wheels.
as my rolling weight is about 10,000 lbs, it'd sure help.
without any engine, smog, or computer changes, by the way.
if interested, email me privately, and i'll send you the guys contact info.
sorry for drifting off topic, but i'm weak....
randy
