xguard
- Baton Rouge, LA
We have a non-fused service disconnect, from the load side the conductors go to a panel and land on the main circuit breaker. The neutral and ground are bonded in the non-fused service disconnect. Should the neutral that runs from the service disconnect to the panel be sized using 250.66 as a minium? The service entrance conductors are #2 and this neutral from the disconnect to the panel is currently a #10. Should it be sized as a #8 based on 250.66? The neutral load for this installation is very small, only a few amps max for control components.
