A 200A 480V circuit breaker in a MCC in an existing building is feeding a new building. Code says that the incoming service conductors must terminate at some type of service disconnecting means. I'm trying to decide which of the following would be better as a choice for the disconnecting means: a non-fusible disconnect switch or an enclosed circuit breaker. I believe the main difference is that the circuit breaker will trip when overloaded, whereas the non-fusible disconnect will only disconnect power to the new building when manually switched. The circuit breaker would prevent someone from having to walk to the existing building and flip the breaker back on if there's ever an overload, since the breaker in the new building will have already tripped. Therefore, I'm leaning more towards the enclosed circuit breaker. Am I missing something? Are there other benefits to having a non-fusible disconnect that I'm overlooking? The cost difference between the two isn't an issue, I'm just looking for what would be best. Below are a couple examples of the types of switches and circuit breakers I'm talking about. Thanks.
http://www.eaton.com/Eaton/ProductsServices/Electrical/ProductsandServices/ElectricalDistribution/SwitchesandDisconnects/SafetySwitches/HeavyDuty/Non-Fusible/index.htm
http://www.eaton.com/Eaton/Products...Breakers/100EnclosedCircuitBreakers/index.htm
