1793
- Louisville, Kentucky
- Inspector
So, recently I have been having a lot of customers wanting me to ?change two prong receptacles with grounded. 99% of the time the circuit is only a two wire circuit so According to Article 406.4(D) I can only change ?like for like? or the GFCI replacement.
If I can get a wire to the receptacle and ?Tap? the Ground System per 250.130(C)(1) or (2) I can replace with a Grounded Receptacle.
Does the length matter and can it run separately to the branch circuit wiring?
I would like to hear what peoples thoughts are on this matter, is it necessary to go through this trouble? If ?No? how would you explain this to your customer?
