motorsportsjs
- PA
Hi,
I'm having an issue finding a cord that fits the required color code for a 120/240 50A non-grounding angle plug. I cannot find anyone that makes 6/3 SO with red, black, and white conductors. I've tried several wire suppliers and eventually called the plug manufacturer. I asked them if they knew where this cord existed and, more or less, their response was it doesn't. I've got two questions. Does it exist? If not and I use 6/3 SO with a white, black, and green conductor, can I tape or heat-shrink the green wire to make it red and still be within code? Cord manufacturers specify the green conductor is for grounding only so I'm not sure if taping it would be acceptable. Is there another cord that I could use for a short (4') extension cord application? Thanks in advance for help!
