I just looked at a job yesterday. The owner has old, cloth covered romex without a ground. They asked me about ways to combat the problem. I explained about using a GFCI as in 406D3. The owners told me that two other contractors had told them about running a external ground wire to the ground on the recep. I asked them where they thought the contractors were going to bond to. The reply was to a ground rod and the well case. After thinking about this, I have seen this application done before, but goodness, It surely can't be in the code (I have looked) and it goes against all sound current flow/trip principles that I have learned. Am I missing something? Even at 25 ohms on a rod, you have what, 4.8 amps of current flow? Anyhow, has anybody seen this and can someone set me strait if this practice is at some level safe.
Thanks
Thanks
