501.4(B)(3) Nonincendive Field Wiring.   Nonincendive field wiring shall be permitted using any of the wiring methods permitted for unclassified locations. Nonincendive field wiring systems shall be installed in accordance with the control drawing(s). Simple apparatus, not shown on the control drawing, shall be permitted in a nonincendive field wiring circuit, provided the simple apparatus does not interconnect the nonincendive field wiring circuit to any other circuit.
 FPN: Simple apparatus is defined in 504.2.
 Separate nonincendive field wiring circuits shall be installed in accordance with one of the following:
 (1) In separate cables
 (2) In multiconductor cables where the conductors of each circuit are within a grounded metal shield
 (3) In multiconductor cables, where the conductors of each circuit have insulation with a minimum thickness of 0.25 mm (0.01 in.)
