jjwsjoberg
I have a question on non linear loads. I want to run three networks in a 3/4 inch pipe. Three phase 4 wire. Pulling number 12 thhn. Is this ok in a small office building with flourecent lighting. The code states when non linear loads are the mojority of the load you count the neutral. Which would make the ampacity down to a 15 amp but what is considered most of the load. Is this a factor or is the small scale of the little bit of lighting and computers in the small office feed on a 200 amp panel ok to be considered linear. I quess my question is if that is true than are all loads other than electric heat and incondesant lighting victim of counting neutral? This would mean in most commercial buildings all recep and lighting circuits would need to have there neutrals counted for fill and derating. This seems off anyone???????????
