by Luke250.8 Connection of Grounding and Bonding Equipment.
Grounding conductors and bonding jumpers shall be connected by exothermic welding, listed pressure connectors, listed clamps, or other listed means. Connection devices or fittings that depend solely on solder shall not be used. Sheet metal screws shall not be used to connect grounding conductors to enclosures.
I am not sure, as soldering was before my time but I think simply twisting the wires together first, then soldering would be OK. This is just how the old ones where done that I opened.To use solder, the splice 'shall first be spliced or joined so as to be mechanically and electrically secure without solder and then be soldered.
This section is only talking about solder as it relates to devices or fittings.Connection devices or fittings that depend solely on solder shall not be used.
Well you better throw out the green 'grounding' screws cause those ain't listed either.Originally posted by peter d:
As Charlie said, is solder a "listed means" of connection?
Yeah, I know you like to get a good discussion going. It helps us all learn something.What I will argue for here many times has nothing to do with how I wire
