Non-Metallic-Sheathed Cable
rmonroe
I will be wiring a office inside our factory. The wiring will consist of general lighting and receptacles. Looking at the N.E.C I see nothing that prohibits Nonmetallic-Sheathed Cable(Romex).
Should I look deeper inside the N.E.C.?
Thanks
rmonroe
Re: Non-Metallic-Sheathed Cable
It would depend on the type of construction of your building. If it is type I or II (noncombustible) you can't use it. If it is type III, IV or V (combustible) then you may use it. Look out for suspended ceilings, however, because you can't use it there.
