Re: non sds?
Justin, this is a difficult question to answer. The UPS may or may not be SDS. Need more info to help you.
It depends on many factors. If it is plugged into a recept, it is not SDS. If it is a dual conversion type, it may or may not be SDS.
Your best bet will be to look in the installation instructions. If it requires a GEC connection, it is SDS. Some manufactures even make it optional.
As a general rule, units larger than 7.2 KVA are SDS. Units less than 7.2 KVA may or may not be SDS
[ April 13, 2004, 09:08 AM: Message edited by: dereckbc ]
