mshields
- Boston, MA
I have a couple of pad mounted transformers (1500kVA) on a project. They were pre-purchased some time ago but are not yet installed. The area in which they are to be installed is suddenly more congested than was the original plan and I?m being asked to shoe horn these into a smaller place than I?d prefer.
To my knowledge, the only code requirement is for the work clearance in front of the units. I know that for ordinary dry types, UL requires 6 inches around the unit. Does that apply to Pad mounted transformers as well (don?t worry there will be more than that ? I?m just trying to determine requirements here). Is there a greater requirement for transformers over a certain KVA?
In general what is the minimum space required or recommended on the sides and to the rear of a pad mounted transformer?
Thanks,
Mike
Thanks,
Mike
