MR. S
 - Connecticut
Is there anywhere in the 2011 NEC that states a nonferrous ground rod only needs to be 1/2" in diameter?
			Trying to drive a 1/2" aluminum ground rod in most soils will be frustrating at best.Maybe. See 250.52(A)(5)(b)
Rod-type grounding electrodes of stainless steel
and copper or zinc coated steel shall be at least 15.87 mm
(5⁄8 in.) in diameter, unless listed.
That would be a little soft too. A bronze or brass alloy could be made stiffer and more likely to survive being driven.you can't use aluminum as a ground rod, I'M thinking more of a solid copper rod
Also bronze would be more corrosion resistant. But on the expensive side.![]()
1/2 copper ground rod is very common. Google is your friend.
On the first two pages of my search, each and every unqualified reference to "1/2 inch copper ground rod" turned out on closer inspection of the linked page to be "copper clad", "copper coated" or "copper plated" in the specs, even though the first page often just said "copper rod".1/2 copper ground rod is very common. Google is your friend.
