Not NEC, but IEC 60947 wire color code
wireman
Inactive, Email Never Verified
We just got a job where we have to comply with IEC 60947 and among other things, I'm trying to find the color code for:
415VAC hot (A, B, and C phases)
415VAC system's neutral (similar to 480/277 I assume??)
240VAC Hot (A, B, and C phases)
120VAC system's neutral
24VDC +
DC -
Any help would be appreciated.
Thanks,
IEC 60947 Standards for low-voltage switchgear and controlgear
The PDF version of this standard is only about $400. Maybe you should just buy the standard. There are probably some nuances that you won't be able to get out of a one paragraph description from a more or less anonymous Internet poster.
Having read the standard, I can tell you that you are in for a shock if you are going to try and modify US style gear to meet this standard.
