petersonra
- Northern illinois
- Semi-retired engineer
More along the lines of how do I "fix' this.
I belong to a club. Some overhead light fixtures mounted to a metal plate have been damaged over the years.
A club member is an electrician and agreed to replace them if I would go get the parts for him. I went looking for a surface mount incandescent fixture and found nothing that would replace the existing damaged fixtures, as they were all oriented with the bulb vertical. The existing fixtures are all oriented so that the bulb is horizontal which gives more head room.
I thought maybe I could get some short flourescent strip lights with the plastic cover. They would fit but can you come in the side of these things? No way to come through the top, as there is a 1/8" or 3/16" steel plate there.
the existing fixtures are wired in 1/2" EMT from a jbox about a foot away. It would appear to be easy to remove the EMT and install a short length of flex in its place and then come in through the side of the strip light. but I have never seen that done before.
Next question. the steel plate has the light fixtures hung on it. Does that make it likely to become energized? If so does that mean it needs a bonding wire?
