woodsniper
I am looking for a 200amp/single phase/3 wire/main breaker panel with lugs at bottom ( to hook up another 200 amp sub-panel) /outdoor/ with 4 -220v breaker slots.
Around here we call them mobil home panels. We mount on a pole to feed the mh and sometimes use the 8 ckts to power the AC condenser or security light. I use mostly Cutler Hammer BR style but I think most manufacturers make them. Should be available from any good supply store.
That would be an enclosed breaker rated for service entrance, Nema 3r enclosure.
But check out NEC article 230.71 which allows up to 6 switches or breakers, grouped together, to serve are the main service disconnect.
A single main disconnect may not be required.
BILLY
