bolognaman
New member
My 4th year apprenticeship class has been having a debate over how to interpret the notes from table 220.55, mostly over the following problem which was written by the instructor:
3 kw cooktop
6 kw wall oven
14 kw range
What is the demand factor?
One arguement is that you can only use one note for a calculation, so you would add the 3 kw and 6 kw together (note 4), get the demand factor for that number and then separately get a demand factor for the 14 kw.
The other side is to add the 3 kw and 6 kw together (note 4) and then take the two values, 9 kw and 14 kw and use note 2 to figure the demand factor.
Then the random guy in the back said to just get the demand factors for all three separately then add them together, since one is column 1, another column 2 and then column 3.
I tried to find a relevant thread in the forum, but none quite hit this conundrum. I'm looking for the method, not an answer to the problem, although if you need to work it out to prove the method, be my guest. Thank you for your input.
-Jason
3 kw cooktop
6 kw wall oven
14 kw range
-Jason
