electricmanscott
- Boston, MA
Another Ice Storm victim brought back to life. Replaced with fancy new SE cable. :smile:
At least the strap is bonded. Sort of.
Looks like it to me....Its a wonder poco didnt red seal it.....Are my eyes deceiving me or is that meter digital? No close up on the meter face. :-?
Neither. It's a (at one time) weather-proof cable-clamp. There's a rubber gland with an oval home inside. Tightening the screws compresses the rubber around the cable. The modern version has a nut like a compression EMT connector.I've never even seen a meter can like that, is that some sort of a gromment fitting on top, or is it a bonding means to the sheath?
In the sense that the readout is an LCD, yes.Are my eyes deceiving me or is that meter digital? No close up on the meter face. :-?
I've never gotten bent out of shape about old service cable with exposed neutral strands. They're no more hazardous to touch than the meter base itself.
No worse than exposed conduit.I know SE is legal, but I just dont like having exposed "unprotected" conductors peaking through the so called outer neutral protection.....
Which would be ...?I seriously wonder if large tranny fuse would actually blow in the right conditions...
With ALOT of holes in it.....
Which would be ...?
Generally not a long-duration event.Like a primary fuse on let's say a 50 or 75kva xfrmr, and those flimsy neutral strands on a #4 SE cable coupled with a "not so" serious ground fault in the se cable..........???
