attomsriver
- New Jersey
Hello:
I monitor, reset alarms and enable /disable points for Fire systems in facilities I work in.
My dealings are mostly related to the H.V.A.C /smoke damper side of fire systems.
I consider myself a newbie, and I have a couple of questions.
All our Honeywell and Simplex systems use two wires for all the devices and modules.
1) Is it safe to say that all the devices are polled by some sort of RS-485 protocol , and that they are also powered (flashing led's) by the same power?
2) On the Honeywell Notifier all points are addressed as Loop ( that is the circuit) , node number and then device number(address).
In H.V.A.C. controls a node is an addressable device attached to the network.
Is it safe to say that a node in a fire alarm control system is a point at which lines intersect or branch ?
Thank you
Thank you
