Is there any place in the code that states how many threads need to be engaged on a nut when securing a lug to a stud? The cables in question are current carrying conductors. I've had no luck locating anything yet.
We dealt with consultants and some had "interesting" specifications.Is there any place in the code that states how many threads need to be engaged on a nut when securing a lug to a stud? The cables in question are current carrying conductors. I've had no luck locating anything yet.
I think as long as the torque is correct it probably does not matter.
No the threads need to be past the fastener, I can't find the why but its probably to develop the correct torque and not deform the threads.
In the naval nuclear power program we allowed three threads.
that is a naval nuke requirement perhaps.
if it is able to develop the correct torque what difference would it make?
Seems kind of iffy if it would stay torqued if there are only one or two threads engaged.
Allow me to punctuate:
"No, the threads need to be past the fastener..."
ASME B31.3, 335.2.3 "Bolt Length. Bolts should extend completely through their nuts. Any which fail to do so are considered acceptably engaged if the lack of complete engagement is not more than one thread."
Wouldn't the first step be to determine what the minimum size of fastener is required?
If you have a 3/8" bolt/nut when a 3/16" would have been sufficient you may not need as many threads engaged as you would have needed for the 3/16 bolt.
I would think the characteristics of the fastener come into play in determining minimum required as well - hardness, type of metal (alloy) number of threads per inch, etc.
where does it say this?
That's much too sensible here.............That seems like over thinking it to me, but then the whole thread seems kind of like over thinking.
I gotta ask - If the OP is worried about having enough threads engaged, why not just get a longer bolt?
