J j rae Senior Member Apr 22, 2008 #1 Is there a number of grounds that you can put on a lug?? also under 2008 I understand that in residential you can't put a ground and a neutral under the same screw on the neutral bar in the main panel.
electricman2 Senior Member Location North Carolina Occupation Retired Electrical Contractor Apr 22, 2008 #2 j rae said: Is there a number of grounds that you can put on a lug?? Click to expand... See the instructions on the panel label. Most will allow more than one. j rae said: also under 2008 I understand that in residential you can't put a ground and a neutral under the same screw on the neutral bar in the main panel. Click to expand... This has been true before 2008 regardless of location. See 408.41, 2005 NEC.
