jjkind
- Las Vegas, NV
Greetings all,
I'm new to the forum, but thought that this was an excellent place to pose a question that has perplexed me for several years regarding the nuisance tripping of a residual-current device.
Here's the story:
I own an apartment in a small building in Buenos Aires, Argentina. When I moved in several years ago, my unit was equipped with a residual-current device along with a separate current protection circuit breaker (I use the past tense because I ultimately had to remove the residual-current device to stop the nuisance tripping).
To give an idea of the building, there are 4 units and service is distributed to each individual service panelboard (within the units) from a main distribution, multi-panelboard with the service disconnect, electrical meter, and main circuit breaker for each unit. Just to be clear, each unit has a circuit breaker external to the unit (located next to the service disconnect) and one inside of the unit in the unit service panelboard, along with a residual-current breaker (basically a whole-house GFCI...used in place of GFCI outlets, not something I had seen before).
I began having problems almost immediately with my residual-current breaker tripping for no apparent reason. Over the course of several days I came to realize that the nuisance tripping was coinciding with the arrival of my neighbor (unit below used as an office). For reasons that I cannot explain, he insists upon using the main circuit breaker in his service panel to shut off electricity to his unit EVERY DAY when he leaves. I left my doorway open one day when he arrived, and sure enough, just as I heard his circuit breaker "click," my residual-current breaker tripped.
I did some more experimenting over the next few days and found that my residual-current breaker would trip with a light load (watching my small TV, for instance - maybe 150W), but it would not trip when I was using a larger appliance like the washing machine.
The current threshold for the residual-current breaker is 30mA, and whenever it trips I can reset it and it holds without tripping - meaning that, for reasons that I cannot explain, the fault current is only exceeding this value in the moment when my neighbor turns on his main circuit breaker, and only when I am using a light load.
I tried to talk to local electricians about the issue - and I even called technical support with the distribution company at one point in time - but nobody has been able to offer me suggestions on potential corrective actions to take to eliminate the problem. As I mentioned, I ultimately had to take the residual-current breaker out of the system to prevent the nuisance tripping.
I've latched onto the idea that there must be some sort of objectionable current path in the electrical system, but what makes no sense to me is why or how my neighbor operating his main circuit-breaker is affecting my residual current breaker.
Has anyone seen something like this before or have an explanation?
Thanks for reading!
Regards,
Jeremy
Here's the story:
Thanks for reading!
Regards,
Jeremy
