shortcircuit2
- South of Bawstin
Is there any engineering practice relative to the spacing of a grounding electrode system of a structure with utility service and the grounding electrode system of the outside pad mount transformer that feeds the structure?
For example, if an outside utility pad mount transformer with 480/277 volt wye secondary with its typical grounding electrode system ground ring and corner ground rods were say within 4 feet of the structures grounding electrode system...would there be a parallel path in certain conditions through the earth for neutral current to flow on the structure grounding electrode system to the transformer grounding electrode system back to the transformer?
