NEC 250.20 (B)(2) requires grouding for utility transformer where the system is 3-phase, 4-wire, wye connected in which the neutral is used as a circuit conductor. It is not clear if the grounding conductor for transformer is allowed to connected to electrical grounding system for main service. If it is allowed (and it is done at most cases), I think that will result in objectionable current in electrical grounding system between main service panel and utility transformer when any unbalanced current existed in neutral cable.
That is the same idea as grounding for Separately derived systems.
Is it a problem to tie the grounding conductor for utility transformer to electrical grounding system? Any comments are welcome. Thanks.
