clausb
- Rutland, Vermont
We have been specifying the wiring of the new style exhaust fans to be connected to the local receptacle or lighting circuit in bathrooms. With the old set up, you would control with the light switch or with a separate, dedicated wall switch. The new style fans run on low speed at all times when the bathroom is not occupied and then runs at full speed when occupancy is detected within the bathroom.
Question is, where do we put the local disconnect switch? We do not want to use a standard wall switch because that will cause the fan to not operate at the lower speed when no one is in the room and the switch is toggled off. The AHJ says we cannot use the cord/plug connection in the fan as a disconnecting means because it is not "readily accessible" without a ladder. I am considering a keyed switch, located behind the bathroom door or some other location where it is out of they way and labeling it as the exhaust fan local disconnecting means, but it just seems kind of goofy to me.
Has anyone had any experiences with this type of installation? Am I not seeing something that might be obvious to others?
Thanks for any help you can provide.
