anothaparson
- Dedham
My customer is looking to control his garage lighting through motion or a digital timer. I recently installed a digital wall switch timer by Sylvania. Check it out I think they are pretty nice!
http://www.hardwareinnovations.com/products.asp?dept_id=1008&product_id=10060
After setting the date, time, and a new feature your zip code the switch will turn on the lights at dusk and keep them on for 2, 4, 6, or even 8 hours while allowing you to manually control them as well. The customer was so impressed with the product they had me install three more.
This product is designed to be used primarily for single pole applications. I am providing a brief description of a 3 way situation in hopes of gaining some knowledge or advice in providing the customer with the best solution.
They have a 3 car garage with a side door entrance to enter the garage, and adjacent to but inside the garage there is also an entrance into the home. These are the locations of the 3 way switches. Is there any way to use either the occ. motion switch or digital wall timer switch in one of the locations without eliminating the 2nd location switch? My first thought is to install a ceiling mounted occupancy motion sensor, and leave the 3 pole switching as is. Is this my best option, unfortunately for the customer it is the more expensive option compared to just adding a switch.
Any thoughts or questions in helping me provide them with the best option for lighting up this garage at night without them having travel to either location would be greatly appreciated.
Thank you in advanced!
