Dquist
- Northern Illinois
I'm Trying to understand what is required when a plan calls for a Ceiling occupancy sensor override switch. Is the intent only to be able to keep the light off? (i.e for a projector) In that case it is simple enough to have the hot pass through a normal switch. But what about the case of a "forced on?" Is this a requirement of these override switches? Or is it only forced off?
I also have a set of plans which is calling for momentary contact switches. Is this so the area will be able to default back to occupancy sensor control? (Using a normally open MC switch)
Thanks for the help.
