hydeisland
- San Diego,CA
What is your common practice for wiring occupancy sensors with power pack? I ve been "breaking" the switch leg between the switch and the light. Basically the "line" is switched and load going directly to the load ie the light, so basically there is always constant power at the switch. A colleague has told me I should be wiring so the load is essentially the constant hot terminal on the switch and the feed is the line. I see no difference in functionality, the only difference being the way I do it there is always power in the switch, in his way there is always power in the power pack.
