MD84
- Stow, Ohio, USA
I need to provide two levels of light output from the same luminarie depending on manual or sensor activation.
The sensor activation needs to be when motion is detected and ambient light is low. This light level will be dimmed to a low output. This will ideally have a low off delay.
Manual activation will be turned on by a switch or button. This light level will be full output.
Ideally this will be controlled by a single yoke as I am retrofitting existing installation.
Does anyone know of an occupancy sensor that will do this? Are double stack occupancy sensor / toggle switch available? Any issue with paralleling dimming occupancy sensor and toggle switch?
