OCPD for multimotor AC equipment
cppoly
New York
How do you interpret 440.22(B)(1):
Where a hermetic refrigerant motor-compressor is the largest load connected to the circuit, the rating or setting of the branch-circuit short-circuit and ground-fault protective device shall not exceed the value specified in 440.22(A) for the largest motor-compressor plus the sum of the rated-load current or branch-circuit selection current, whichever is greater, of the other motor-compressor(s) and the ratings of the other loads supplied.
I can interpret this two ways:
1) Not to exceed the largest compressor RLA (175% - 225% round down) then add remaining RLA then round down.
Example:
49.6A compressor RLA
9.2A fan motor RLA
49.6 x 1.75 = 86.8A , round down = 80A + 9.2A = 89.2 round down = 80A
OR
2) Not to exceed largest compressor RLA (175% - 225%) + remaining RLA then round down.
49.6 x 1.75 + 9.2 = 96A round down = 90A
Thanks
Example:
9.2A fan motor RLA
OR
Thanks
Look to the manufacturer's installation manual, since their recommendations take into consideration the advantage of the suction return to cool the motor windings.
Thanks.
Sometimes manufacturer's get it wrong on their spec sheet so you have to calculate the value yourself.
440.22(B)(1) seems ambiguous though.
That's reason the manufacturer's Installation Manual recommended MCA do not match the manual calculations.
