Okay...so I have been reading about secondary OCPD for transformers and there is alot of info in these Forums.
I would like to get some clarification ....
If I have a 480/277 Panel in a electric room with a breaker feeding the primary of the transformer, transformer hanging in the ceiling 10' feet away, and the secondary feeding a 208/120v Panel on the other side of the room and it is more than 25' away do I need to insert a disconnecting means in between the secondary side of xfmr and the low voltage panel; though the panel has a main breaker.
Does the 10' or 25' tap rule for xfmr's apply? Or is this not a tap?
Any help on this issue would be appreciated.
When do I need to have a disconnect on the secondary side of the xfmr? When it is out of sight? or more than a certain footage?
