I have a question as to weather it is typical to provide OCPD (fuses or breaker) on both positive and negative side of a DC circuit or if it is normally just required on one?
My understanding has always been a matter of how the circuit is grounded and weather the negative side is grounded or the system is floating. For instance with negative side grounded (Ex car battery) i typically only see OCPD on the positive side of circuit whereas as on a floating system (Ex station service batteries) I typically see both positive and negative side of circuit fused.
With a system that is not grounded on the negative side, and is floating, is there a potential for a ground fault to occur on the negative side of the circuit that the OCPD on the positive side would not clear?
