When installing a welding receptacle must the receptacle rating be smaller than the OCPD upstream feeding the receptacle.
In other words If I had a 100A breaker feeding out to a 100A non-fused disconnect which was connected to a 60A welding receptacle is this incorrect? Should the welding receptacle be a 100A rated receptacle or the breaker changed to a 60A?
Does the same apply for convenience receptacles?
