Hi,
Doing a tenant build-out in an office building and the plans call for my power circuits (non-lighting) to be grouped as networks (one neutral for three hots each on a different phase.) Ive always just marked the neutral with the shared circuit numbers on them and then landed each hot on its own breaker. Today at work one of my co-workers told me that it is now a code requirement to land networks on 3 pole breakers so that all lines will break simultaneously and interrupt all current through the shared neutral. In a way this makes sense and in another it seems kind of dumb. Ive always thought that the only instance in which i had to use a multi-pole breakers was when my ungrounded conductors landed on the same yoke or on the same terminal block ie: multi-circuit track or wye connected 3 phase equipment. Can someone please clarify this for me? Thank you.
