Hello to all!
I was a sparky for 12 years before going into residential maintenance and being a landlord. We have a 4-plex that was a SF home, built in 1919 and converted in 1940. Each apartment has it's own small sq d sub panel, original. service change about 10 years ago, permitted. After we bought it, I removed a lot of the leaking iron pipe with pex and re-jumped (bonded) the steel pipe to the CW entry and did jump the regulator. No problems until after the neighbor's tree comes down and I can see that the neutral has been disconnected at the pole for years. I call it in and the power company hooks it up, but now one tenant's tub faucet handles are shocking them. I check and jump the pipes leading to the tub faucets to ground (CW entry), and then had to bond to the tub because it was still shocking them but worse after bonding the pipes. Now the tub & faucets do not shock them, but the chrome plated brass soap dish (original) shocks them. I have checked but cannot measure any voltage. Has anyone faced a similar situation? Maybe just replace the soap dish with porcelain and call it good? Lathe & plaster walls...
Thanks, Tim
Thanks, Tim
