Odd Issue
drooney57
New member
I have a technical question, I have a small granny unit on my property, it has a 220V panel with 6 individual breaker spots, I have 4 - 110 breakers for lights, outlets and a small 110v water heater booster. I have 1 - 220v breaker for the tank-less water heater, all the light bulbs are LED. Well, for some reason, now one of the lights flickers when the 220v water heater is active. Does this make sense? I have not changed the bulb yet, as I have to remove and disassemble the light fixture. thank you
You probably have a switch controlling the fixture with the flickering lamp. Check the voltage for voltage drop when the tankless heater is energized.
This site is designed for:
  • Contractors
  • Electricians
  • Engineers
  • Inspectors
  • Instructors
  • Other electrically related individuals
This NEC® Forum is for those in the electrical and related industries. Questions of a "How-To" nature by persons not involved in the electrical industry will be removed without notice.
Knowledge and the practical application of the National Electrical Code is an essential part of all electrical installations. If it's important for you to understand the National Electrical Code, then look no further.
To better help us serve you, please be sure to update your account details with your occupation field and location if you have not done so already. You can access your account details by clicking on your account name at the top right of the page when on the forums.
