jerrygar
- Keaau, Hawaii
We recently had a massive electrical storm. I know of two house fires, four telephones blown off walls, one stove receptacle blown off a wall, one automobile tire flattened, one destroyed charge controller and three destroyed inverters and numerous grid failures. That is probably only a small percentage of the damage.
I am now installing a small (8 175 watt panel) off grid system (there are many in this area.) What is the best lightening protection?
Based on what seems to be current best practice, I plan to:
Install 3 ground rods spaced 10' apart (we have no soil, only lava rock, so the connection to ground is bad.)
Bond the solar panels and connect to the rods with #6
Connect the charge controller to the rods with #6.
Connect the negative side of the batteries to the rods with #6.
Bond the charge controller, inverter and other metal parts with #6.
Connect the 110 v. distribution panel to the rods with #6.
Bond the hot and neutral in the distribution panel.
Install lightening ancestors on both the AC and DC sides.
Connect the telephone ground to the ground rods.
Comments or suggestions?
Thanks,
Jerry
Thanks,
Jerry
