It is definitely a common inquiry, but I can't say that I completely understand it. When you figure the "all in" cost of electrical energy from a PV system with batteries, it is nearly always much more more than buying kWh from the grid if the grid is already available. I guess I can see the romantic allure of living "off the grid", but if you have a grid connection, even if you are only using it as a safety net, you aren't off grid. If the grid is available and dependable, your economic interests are better served by spending your money on grid tied PV to offset your electricity bill. If you have outages that you want to be able to bridge, you are better served by buying the smallest battery system you would need to accomplish that purpose and only using it when you need it; battery systems are expensive, and they degrade proportionally with the number of discharge/recharge cycles you put them through.
That's my opinion, anyway.
