I am laying out branch ckts for a remodel in an office complex. No prints to speak of and its kind of a design build. Nothing fancy. Just some new drop-in fixtures and new outlets. The outlets however will be powering all the office equipment in each space. I have touched briefly many times about the issues of Non linear loads and overloads and overloading of neutrals. My questions are this: How common is it to run multi wire ckts on a shared neutral that feed office spaces. We are starting to design the conduit runs and the wire fill for them. Its three-phase power and I am wondering if pulling multiwire ckts with a common are prudent. Also, can?t you even get overloading of you neutrals with just the new electronic ballast lighting? Anyhow, what is the norm now with the high electronic loads in offices? Does each ckt get its own neutral, or are they still shared. Multiwire sharing also helps on your derating count. You don?t have to count the neutral as a hot conductor. Actually 310.15 B 4 (C) tells us we need to count it I guess. Anyhow, any insight would be great!
Thanks in advance
Thanks in advance
