What is a tunnel kit?In addition to the bad offset there is no way to install the required tunnel kit with the location the raceway enters the panel. It needs to enter against the left wall.
I'm also amazed how often inspectors don't catch the tunnel kit not being installed.
Must be an underground only meter combo? On the combo’s, the meter is usually at the top, with the tunnel to the left if used as underground. Haven’t seen one with the meter at the bottom.In addition to the bad offset there is no way to install the required tunnel kit with the location the raceway enters the panel. It needs to enter against the left wall.
It’s a box that separates the utility feed to the line side of the meter. It’s removable to allow the service conductors and conduit to be installed.What is a tunnel kit?
What rule in the NEC would require a tunnel kit?In addition to the bad offset there is no way to install the required tunnel kit with the location the raceway enters the panel. It needs to enter against the left wall.
Not NEC but EUSERC (California and other Western utilities)requires all un-metered conductors to be in sealed barriers. I believe the instructions with the the panel require the tunnel for overhead use.What rule in the NEC would require a tunnel kit?
Offset nipples are not running threads. Running threads are threads cut on a conduit usually 2-3x longer than a standard thread so yo can run the locknut on a long way. Picture installing a rigid conduit between 2 fixed boxes with no way to get the pipe inIs it allowed to use offset nipples with rigid couplings?
344.42(B) says "Running threads shall not be used on conduit for connection at couplings."
I agree with you that they are two different things, and so 344.42(B) would not apply to offset couplings. Both have a threaded area that is not tapered so that a locknut can be freely run across it. But on offset nipples the proper term would be straight threads.Offset nipples are not running threads. Running threads are threads cut on a conduit usually 2-3x longer than a standard thread so yo can run the locknut on a long way. Picture installing a rigid conduit between 2 fixed boxes with no way to get the pipe in
