Ohio licensing requirements
gman2003
Florida
What are the licensing reqiurements for the state of Ohio? Currently I have a Broward County journeyman's license here in Florida and I was wondering how Ohio does their licensing. Do they go by counties also? Who can I contact to get info.? Thanks.
jtb
Pennsylvania
Re: Ohio licensing requirements
Thanks Mike. I am a former electrician turned engineer, from PA. I live I Ohio now, and feel strange that I am not permitted to grab the weekend job.
jxofaltrds
Inspector Mike®
Mike P. Columbus Ohio
ESI, PI, RBO
The state is confusing the lic. issue by "now" saying the following text only applies to commercial contractors. Some counties will still allow anyone to do residential work just by paying a registration fee.
IMHO the ORC is very clear. I hope the info I pasted helps you.
Mike P.
The Ohio Revised Code says the following:
? 4740.08 Reciprocity with other states.
Upon application to the appropriate section of the Ohio construction industry examining board and payment of the fee determined pursuant to section 4740.09 of the Revised Code for the issuance of a license, the appropriate section of the board shall authorize the administrative section of the board to issue, without examination, a license to an individual registered, licensed, or certified in another state of the United States, provided that the appropriate section of the board determines pursuant to the rule adopted under division (A)(5) of section 4740.05 of the Revised Code that the requirements for registration, licensure, or certification under the laws of the other state of the United States are substantially equal to the requirements for licensure in this state and further provided that such other state extends similar reciprocity to persons licensed under this chapter. The appropriate section of the board may withdraw its authorization to the administrative section for issuance of a license for good cause shown prior to the administrative section's issuance of the license.
HISTORY: 144 v H 402 (Eff 7-31-92); 148 v H 434. Eff 9-18-2001.
The effective date is set by section 5 of HB 434.
? 4740.01 Definitions.
As used in this chapter:
(A) "License" means a license issued by the Ohio construction industry examining board to an individual as a heating, ventilating, and air conditioning contractor, refrigeration contractor, electrical contractor, plumbing contractor, or hydronics contractor.
(B) "Heating, ventilating, and air conditioning contractor" means any individual or business entity who satisfies both of the following:
(1) For compensation, directs, supervises, or has responsibility for the means, method, and manner of heating, ventilating, and air conditioning construction, improvement, renovation, repair, or maintenance on a construction project and who offers, identifies, advertises, or otherwise holds out or represents that the individual or business entity is permitted or qualified to perform, direct, supervise, or have responsibility for the means, method, and manner of heating, ventilating, and air conditioning construction, improvement, renovation, repair, or maintenance on a construction project;
(2) Is a tradesperson or employs tradespersons who perform and who are trained to perform heating, ventilating, and air conditioning construction, improvement, renovation, repair, or maintenance on a construction project.
(C) "Refrigeration contractor" means any individual or business entity who satisfies both of the following:
(1) For compensation, directs, supervises, or has responsibility for the means, method, and manner of refrigeration construction, improvement, renovation, repair, or maintenance on a construction project and who offers, identifies, advertises, or otherwise holds out or represents that the individual or business entity is permitted or qualified to direct, supervise, or have responsibility for the means, method, and manner of refrigeration construction, improvement, renovation, repair, or maintenance on a construction project;
(2) Is a tradesperson or employs tradespersons who perform and who are trained to perform refrigeration construction, improvement, renovation, repair, or maintenance on a construction project.
(D) "Electrical contractor" means any individual or business entity who satisfies both of the following:
(1) For compensation, directs, supervises, or has responsibility for the means, method, and manner of electrical construction, improvement, renovation, repair, or maintenance on a construction project and who offers, identifies, advertises, or otherwise holds out or represents that the individual or business entity is permitted or qualified to direct, supervise, or have responsibility for the means, method, and manner of electrical construction, improvement, renovation, repair, or maintenance on a construction project;
(2) Is a tradesperson or employs tradespersons who perform and who are trained to perform electrical construction, improvement, renovation, repair, or maintenance on a construction project.
As used in this chapter, "electrical contracting" does not include the construction, improvement, renovation, repair, or maintenance of any of the following systems using less than fifty volts:
(a) Fire alarm or burglar alarm;
(b) Tele-data;
(c) Cabling;
(d) Sound;
(e) Communication;
(f) Landscape lighting and irrigation.
(E) "Plumbing contractor" means any individual or business entity who satisfies both of the following:
(1) For compensation, directs, supervises, or has responsibility for the means, method, and manner of plumbing construction, improvement, renovation, repair, or maintenance on a construction project and who offers, identifies, advertises, or otherwise holds out or represents that the individual or business entity is permitted or qualified to direct, supervise, or have responsibility for the means, method, and manner of plumbing construction, improvement, renovation, repair, or maintenance on a construction project;
(2) Is a tradesperson or employs tradespersons who perform and who are trained to perform plumbing construction, improvement, renovation, repair, or maintenance on a construction project.
(F) "Hydronics contractor" means any individual or business entity who satisfies both of the following:
(1) For compensation, directs, supervises, or has responsibility for the means, method, and manner of hydronics construction, improvement, renovation, repair, or maintenance on a construction project and who offers, identifies, advertises, or otherwise holds out or represents that the individual or business entity is permitted or qualified to direct, supervise, or have responsibility for the means, method, and manner of hydronics construction, improvement, renovation, repair, or maintenance on a construction project;
(2) Is a tradesperson or employs tradespersons who perform and who are trained to perform hydronics construction, improvement, renovation, repair, or maintenance on a construction project.
(G) "Contractor" means a heating, ventilating, and air conditioning contractor, a refrigeration contractor, an electrical contractor, a plumbing contractor, or a hydronics contractor.
(H) "Tradesperson" means an individual who, for compensation, engages in construction, improvement, renovation, repair, or maintenance of buildings or structures without assuming responsibility for the means, method, or manner of that construction, improvement, renovation, repair, or maintenance.
(I) "Construction project" means a construction project involving a building or structure that is subject to Chapter 3781. of the Revised Code and the rules adopted under that chapter, but not involving the following buildings or structures:
(1) An industrialized unit as defined in division (C)(3) of section 3781.06 of the Revised Code;
(2) A building or structure constructed pursuant to rules adopted under section 3781.181 [3781.18.1] or 3781.21 of the Revised Code.
The provisions of ? 7 of HB 434 (148 v --) read as follows:
SECTION 7. In enacting this legislation, it is not the intent of the General Assembly to classify or reclassify construction activities to place them under the scope of this act, or to interfere with the right of a construction employer to assign employees to construction activities as enunciated by the Ohio Supreme Court in Pipefitters Union Local 392 v. Kokosing Construction Co., Inc. (1998) 81 Ohio St.3d 214, regardless of whether the construction activities are governed by the rules adopted by the Board of Building Standards pursuant to Chapter 3781. of the Revised Code.
