I think you will find as Zog pointed out, that while this meter does have it uses, MOST test performed with this meter are not completed properly. Due to a variety of factors, first and foremost a lack of understanding the proper use of the meter. The primary reason this meter is used is trying to do it on the cheap (labor wise) and folks think it is EASY to use. If you are going to perform any electrical testing the first thing you learn is IGNORE the price. Because all test equipment is expensive. Meggers alone I probably have over 30,000.00 dollars tied up and that is the most basic of testers besides the multimeters and amp clamps.
