PetrosA
- Lancaster, Pennsylvania
This is something I've been thinking about for a while since I got a new clamp meter this year. Although it's not a cheap meter, it's resistance range tops out at 4 kOhms. It was the one spec I didn't think to check since my last clamp meter did everything I needed.
So my question is this - what tests do you do that would normally require more than 4 kOhms range? The one thing I know I need it for is checking floor heat thermistors which generally read between 8 and 12 kOhms, but this seems well below the ranges I'm seeing on some Ideal, Klein or Greenlee clamps which have advertised ranges anywhere from 20 MOhms to 50 MOhms. Where am I going to need that range?
