- Lockport, IL
- Semi-Retired Electrical Engineer
450.23(B) has me confused. An oil-filled transformer will serve a new building. The transformer will be outside, in an area well (i.e., below grade, covered by a grating but still open to the air above). There will be an overhang above the area well, one floor above grade (i.e., the floor of level two will extend over the opening). I don?t yet know what type of fluid will be used, so I can?t design this in accordance with the listing requirements of the fluid.
Is this even going to be allowable? Will I need a fire sprinkler system above the transformer, to protect the second level overhang from a possible fluid fire? Where do I go for information?
