storeytime
- Texas
I am troubleshooting a problem with an oil well pump motor. It is 240V, 1PH, 5HP, 20.2 FLA.
I was called because it kept tripping the heaters. I set them at 25.25A - 20.2 x 1.25= 25.25
On an amperage check under load the amperage was pulling 5-6 amps on the down stroke of the well pump. It was fluctuating up to about 34-37 amps on the pump (up) stroke for about a half second. I was told that the pump would run for about an hour and a half before it tripped the overload heaters.
I'm not real familiar with oilfield mechanics, but I could only come up with these conclusions:
1 - Something mechanical on the pump was making the motor work too hard on the pump action. (Oilfield people set the counter weights on the pump at lightest setting - still tripped)
2 - The motor was not big enough for this well. (Several other wells in this field use this exact setup with no problem)
3 - Something in the well itself was putting it in a bind, maybe blockage or bent casing. (just guessing, again I don't know anything about drilling & pumping. The landowner came by and told me that they had bent the first pipe and had been having a lot of trouble cleaning this one out)
4 - The motor is bad. (I ohmed the motor leads out and they ohmed out good, no short to ground)
Does anybody have any other possiblilites on this or a better way to see what is happening in this situation? I'm going tomorrow to run the pump and do amperage checks for a longer period of time than I did the first time.
