slc410
- Madison wi
- Electrician
first off I would like to ask about 3-phase 4 wire 120/240 (b-phase high leg) wiring. I was told that connecting a line to neutral load to the B phase is not permitted but im assuming that what they're thinking is one will connect a 120v load to this connection which obviously will end not so well. But lets say you connect a load which is rated for the 208 volts which this phase provides isnt this an ideal setup for this situation. I think I remember in tech school that this is why this voltage was created in the first place, to provide multiple voltages without having to have transformers all over the place.
Next, somewhat unrelated, but can you wire a lighting ballast rated for only 277 volts (line to neutral) to 208 volts (line to line)? In my 6 years in the trade I had never heard of this till the other day when a seasoned veteran in the trade said it was ok since both voltages are "single phase".
