Ok to add mini breaker inside disconnect
sfav8r
Is there a problem with adding this mini breaker inside the disconnect? We often add them inside switch gear and there has never been an issue. This is the first time adding inside the disco and I'm not sure If its a problem.
In my opinion it could be fine.
From the UL general directory.
It is the responsibility of the Authority Having Jurisdiction (AHJ) to determine the acceptability of the modification
What is the purpose of the breaker and is it a breaker that the code requires to be readily accessible?
Yet your not going to gig him for the paint that he didn't grind down to the bare metal before he added that additional ground lug ?????
Well dad gum you all.....:)
JAP.
