Fulthrotl
~Autocorrect is My Worst Enema.~
- E
the sordid details:
i've gotta hang a flatscreen over a fireplace
the fireplace is slump stone over cinderblock. it's crumbly
it's covered by 5/8" lath horizontally, on 2' centers, attached with liquid nails,
ramset pins, and spit. with 1/2" drywall on top of that.
i was able to get some anchors to hold in the slump stone. it's not a heavy
flat screen. maybe 35=40 pounds.
i've cut a piece of #12 mild steel for backing, and put two single gang rings
under the bracket, horizontally.
here's the problem... there's only half an inch behind the rings, and i can't
break away the slump stone to make a hole.. the whole thing will come apart.
i have to get a hdmi cable, and power to the two rings. here is my hack
solution.....
i'm going to use a 12' long molded power cable, with a computer plug on the
end, to plug directly into the tv. no outlet behind the tv. i can snoodle both
cables across the 5' to the equipment.
i can go horizontally across the wall, and drop into the equipment area.
getting up into the attic would be a nightmare. horizontal furring, crown
molding, etc.
putting a power cord behind drywall isn't my happy choice, but i'm out of options.
any suggestions? see attached picture for details. there are no sharp edges,
burrs, or hazards to either cable in the wall. just a 5/8" void.
thanks....
randy
solution.....
molding, etc.
thanks....
randy
