I went out to look at this problem for a guy that has a barn located about 60' from his house and in his barn he has problems with his electrical system that was obviously done by every handy man in the area. Anyway the barn has a sub panel out there that has been only been breakered from inside the house with a 60A breaker which feeds the 3- #6s which don't seem to be in any conduits underground to the barn. So at the barn I have hot,hot, neutral no ground so the panel has been bonded at the sub panel location for grounding means (there is no ground rod out there).The problems are this I am getting 126v to the dirt in front of the panel. I'm getting 20v from conduits to the aluminum siding on the barn. I'm getting 107v on one leg and 149v on the other leg when I introduce a load to the sub panel meaning I turn on a light or something and when I turn it off the voltage goes back to normal 126v and 126v to ground.Heres the real weird part to me. Even though I have disconnected the HR that feeds an outlet box at the back of the barn and it is piped in 1/2" emt to a metal box with the hot and neutral in that pipe disconnected I'm getting a consistent sizzling of what sounds like a mini welder just arcing between the box and the emt connectors.That is confusing to me. Anyway my theory as to what is happening out there is that the feed that goes out to the barn is cut or damaged in some way that its causing these things to happen in (ex different potentials of electricity in the dirt all around the barn.) and I was wondering if anybody has any different theories.Any ideas would be appreciated.
